Ноутбук Toshiba Satellite C75D. Модель из бюджетной серии C ноутбуков Toshiba, выпущенная в 2013 году.
How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
It looks like it's a cable as in Step 10 here: Замена ЖК-экрана IBM ThinkPad X41
or in Step 12 here: Замена поврежденного шлейфа ЖК-дисплея ASUS K75VM
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Разборка Toshiba Satellite A215
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
Toshiba Satellite A215 Изображение
Инструкция
Сложность:
Умеренно
IBM ThinkPad X41 ЖК-экран Изображение
Инструкция
Сложность:
Умеренно
30 minutes - 1 hour
Asus K75VM замена поврежденного шлейфа ЖК-дисплея Изображение
Инструкция
Сложность:
Умеренно
25 minutes - 1 hour
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
из
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
из
Добавьте свой ответ
Marie OKeefe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За все время: 1,969
