Volkswagen Passat версий B6 и B7 — это большие семейные автомобили с передним расположением двигателя, выпускаемые немецким автопроизводителем Volkswagen. Модельный ряд Passat B6 производился с 2005 по 2010 год, а модельный ряд B7 — с 2010 по 2015 год в качестве обновленной версии B6.
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Это хороший вопрос?
Счет 3
3 Комментариев
this worked for me omg thank you so much
из
Glad it worked, pass it along...
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Push on brake and hit button forgear shifter a couple of times.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
из
It worked for me. Thank you!!
из
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
Счет 0
2 Комментариев:
I was programming my remote key fob now the fob is stuck in the ignition
из
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
из
Is there a battery in the fob?
If the five won’t come out of the ignition?
Счет 0
Добавьте свой ответ
Darby Rosello буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 42
За всё время: 22,436
