Обновленная в марте 2015 года модель 13-дюймового MacBook Air от Apple оснащена процессорами Intel Core i5 и i7 пятого поколения, что обеспечивает небольшое повышение производительности и времени автономной работы.
USB connection problem with iPhone
Hi everybody,
I have a MacBook Air Early 2015 and an iPhone 5s.
When I plug my iPhone into system my iPhone oscillates connecting and disconnecting rapidly.
I did almost everything: changed the cable, cleaned the dock, SMC, NVRAM reset, iTunes reinstall, iPhone's hard reset and restore privacy settings, even did a clean Mac OS install but nothing changes.
With pen drives, MIDI controllers etc... the USB works properly, and it does with my iPhone if I do not log-in into my Mac, just turning it on and plug the USB in. In that case there is no disconnect/reconnect cycling problem. But, immediately after I log-in it starts up.
I was in two different Apple Service and they said that is something software problem and possibly, a clean Mac reinstall solves it. It did not solved it! I tried to connect my iPhone into other notebooks, there were no problem.
Any idea? (Sorry for my poor English...) And yes, the cable is original.
Это хороший вопрос?
Счет 12
7 Комментариев
What is the MacOS version you are running presently and did you have any issues with your system before? Did it get wet or have something spilled into it?
из Поделиться
Also, is the cable you are now using an original Apple cable? Some third-party ones don't allow enough power through and therefore demonstrate this problem.
из Поделиться
Thanks for the answers!
I am running MacOS High Sierra at the moment, but before the update, Sierra did the same thing... I have no other issues before and Mac never got any wet.
The cable is absolutely original, I tried a few other cables too, and bought a new one just because of that symptom. I read a lot about that problem on the internet, many other users all around the World has the same problem but no one has the solution. (not just with iPhones, some iPads do the same thing...)
из Поделиться
Same problem here, iPad and iPhone cycling power on / off ! what to do ??
из Поделиться
lots of people have this problem; it the Apple's fault not user error
из Поделиться
Показать ещё 2 комментариев
Добавить комментарий
9 Ответов
Выбранное решение
At this point I’m suspecting the system has a USB power issue. These are getting hard to find but I think it’s what you need to test things out: USB Charger Doctor - Current & Voltage Charging Detector as well as Battery Voltmeter & Ammeter. With it you should be able to compare the current draw on a second working system (ideally another MacBook Air of the same series) and yours to see if the voltage and/or current draw is the issue. You might want to also try a second iPhone (again the same series would be best comparison).
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Yeah, I agree that. I have the same opinion, and I said that to the service 2-3 weeks before... But they answered that it can be just a software problem... Shameful...
из Поделиться
I had the same problem with my previous macbook air.
Now i lost my old macbook air and got a new one 2 weeks ago, same problem exist. not just my iphone, but also my wife's iphone. Hence, i strongly believe it's the problem of macbook airs.
by the way, i don't buy cables except from apple authorised reseller, i'm certain they're not 3rd party..
previously when i went to the service centre, they say it might be the USB port on my macbook air had wear & tear effect, & repair would cost a lot. But now this new one i bought having the same problem, i am sure it's a problem of macbook air... can anyone in apple try to address this issue and fix this?
из Поделиться
furoice88 - Is this a brand new, refurb'ed or used system?
Apple does not officially monitor this site so asking Apple for help here won't help you.
The best you can do is bring the MacBook Air back to where you bought it with your iPhone's and cables to show them.
Frankly I would do some tests using the USB Charger Doctor I pointed out above before going.
из Поделиться
Наиболее полезный ответ
I was able to fix the issue by restarting the USB service.
sudo killall -STOP -c usbd
Счет 86
87 Комментариев:
Thanks, I hope this will be helpful for peoples who are on the same boat. Unfortunately I sold my MBA, so I can't try it. :(
из Поделиться
Great solution!
из Поделиться
Thanks, Man!! Finally got it working.
из Поделиться
Are you serious, is it this easy? Yes it working %#*@... took me 1,5 years of searching
из Поделиться
Worked for me yay
из Поделиться
Показать ещё 82 комментариев
This command solved my problem. However, I would suggest that for those with little knowledge of Mac, please do the following steps:
1- Go to Application
2- Go to utilities
3- Go to Terminal
4- copy and paste this command in full : sudo killall -STOP -c usbd
5- press Enter
6- It will prompt you for your password, and type your password and hit enter
7- connect your iPhone to mac
8- The problem should be resolved
Best of luck
Счет 7
17 Комментариев:
thanks Sayed Zamir , this helpt me :) , sudo killall -STOP -c usbd
из Поделиться
Omg Sayed, you are an absolute lifesaver. Thank you!
из Поделиться
Thank you! This worked for me as well!
из Поделиться
YES YES YES! Thank you, you computer wizard!! @Sayed Zamir Hashemi
из Поделиться
Thank you so much Sayed . You really helped me with this, this issue was been troubling me for sooo long.
All thanks to you. :) @Sayed Zamir Hashemi
из Поделиться
Показать ещё 12 комментариев
I had the same problem. The problem is caused by cache and directory issues with the startup disk. BOOTING IN SAFE MODE SOLVED IT. Boot in safe mode (hold down shift key immediately you power the macbook, keep holding it until you see the login screen). To confirm that you are in safe mode (safe mode should be written in red at the top right corner of the login screen). Login, plug in your iphone and the problem is solved. To confirm that the problem is solved, leave safe mode by just restarting the macbook normally (without holding shift). Sorry for the late response. THIS IS A 100% FIX
Счет 2
6 Комментариев:
You save my life
из Поделиться
I can not solved my problem. When i restart my Macbook, problem is not solved. :(
из Поделиться
The safe mode thing solved the problem right now.
из Поделиться
Not only did it not work, my USB ports don't work at all in safe mode. Less than 100% fix.
из Поделиться
Worked like a charm for me too!
из Поделиться
Показать ещё 1 комментарий
i have the same problem but a non-Apple lightning cable worked for me! original apple cable won’t stop disconnecting.
Счет 0
4 Комментариев:
Now here I am: I found a guy, who had the same problem 2 years before. He said that nothing helped him but then he bought a non-Apple lightning cable (ISY IUC-500 type) and it solved everything. I am a little bit skeptic and don't know yet where can I buy that cable but I think it is worth a try.
из Поделиться
I would find it hard to believe a 3rd party cable would be better than an Apple cable (both being new). The length of the cable could be a factor as an example an overly long cable or one which has a USB extension would have a voltage drop which could explain why your iPhone is having problems as your system is on the edge.
из Поделиться
I have an 1 m long lightning cable...
из Поделиться
Don't think thats overly long ;-} A 2 m cable with an extension would be.
из Поделиться
This post is pretty old but I was about to buy the USB charge doctor to check mine but a coworker suggested I try resetting the SMC on my mac and that fixed it in less than 5 mins. So anyone that’s still dealing with this should try that before buying something to check their USB ports. Here are instructions.
http://osxdaily.com/2010/03/24/when-and-...
Счет 0
This trick works great...but it has to be redone.
Why do I have to do it again? I did it about a month ago, and know I have to redo it. Is this normal or did I forget something? t
Счет 0
Open finder
Look for activity monitor
Open the memory tab and search for usbd
Double click it and press “stop”.
Then it should work.
Счет 0
1 Комментарий:
Did not work either
из Поделиться
I plugged the lightning cable to a multiple USB Hub and the Hub to the Macbook pro, and it solved the issue
Счет 0
1 Комментарий:
this was about a macbook air. Mine works in the pro also, but not in the air
из Поделиться
Добавьте свой ответ
Janos Bata буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 30
За последние 30 дней: 142
За все время: 99,551
