Huawei Honor 8 — это Android-смартфон, выпущенный в 2016 году, оснащенный 5,2-дюймовым дисплеем с разрешением 1080p, 4 ГБ оперативной памяти, двойной камерой с сенсорами по 12 Мп, сканером отпечатков пальцев и портом USB Type-C. Модель: FRD-L04.
Can't perform a factory reset
I have forgotten my password and as a result I am unable to reach my settings. I have not performed a back up and I have holiday photos on my phone I would like to keep. I have tried to perform a factory reset but I have been unsuccessful. What should I do?
Это хороший вопрос?
Счет 0
1 Комментарий
If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right
из
Добавить комментарий
3 Ответов
Выбранное решение
@preheat If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right . If you get locked out after to may failed attempts then go here then instead of factory reset in step 4 select wipe cache partition. do that and you will get a new round of password attempts . If you made the password you will eventually get it . Hope this helps
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Tryn to rest huawei android to factory settings but im stuck on formatting/data
из
It bypasses the scrolling option to wipe data
из
[] Turn off your Android device. ...
[] Press and hold the "power", "volume down", simultaneously. ...
[] Release the buttons once your Android device is powered on. ...
[] Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.
Счет 2
4 Комментариев:
This will cause lose of holiday photos
из
yeah i concur... but assuming he cant remember his password how much choice does he have? he can keep trying though until he gets the correct password. And hopefully if he has to reset the device, he has a back up for his files.
из
I hope you dont mind I made a correction to your answer I removed the camera button part as this was incorrect but the rest was good
из
yeah I appreciate it man,... tnx
из
hi, i have reset my honor 8, and now the first steps to log in with gmail account, but i cant continue because wifi is not turnin on!! i cant solve this problem. please help me :(
arberim_d@hotmail.com
Счет 0
Добавьте свой ответ
Lexi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 31
За всё время: 10,081
