Руководство по ремонту и устранению неполадок для беспроводной мыши Apple с поддержкой Multi-Touch. Номер модели A1657 или A3204.
Cannot select with MM2.
Cannot select with MM2. I can move cursor but cannot click. Also disables my ability to select on trackpad. If I turn off MM2, trackpad functions normally.
Это хороший вопрос?
Счет 3
1 Комментарий
Hello!
I had the same problem with the MM2. I could move the pointer but it did not go right or left click. Have a reset of the mouse performed, tried on another Mac.
Nothing worked!
Then I disassembled the mouse according to ifixit instructions and, as in step 7, disconnected and reconnected the data cable.
And the mouse works again like the first day!
I hope I can help some users with the info, because I found nothing on the Internet.
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Try going to system preferences > trackpad > see if "tap to click" box is checked.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thanks, I can select with the trackpad as long as the Apple mouse is disconnected. I am using a cheap external mouse and getting by. I think the Apple mouse is my problem. At $75 I'm going to have to make do with the off-brand mouse. It has made me become more proficient with the trackpad.
из Поделиться
Well. get a used one, I just bought 4 for $45 https://www.ebay.com/usr/tricomputersolu...
из Поделиться
Добавьте свой ответ
James M McMurtry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За все время: 1,519
