Samsung Galaxy Tab 2 10.1 — это 10,1-дюймовый планшетный компьютер на базе Android, относящийся ко второму поколению серии Samsung Galaxy Tab.
Unfortunately Google Store Play has stopped
I keep receiving the message: "Unfortunately Google Store Play has stopped working". How do I fix that? Can I just remove that app and if yes, how do I download a version of that app?
Это хороший вопрос?
Счет 29
19 Комментариев
Google has stoped
из
Unfortunately google play store stopped
из
Thanks for tip. Uninstalling updates worked wonders. Appreciate your help.
из
I need your help
из
What if I cant even open the app
из
Показать ещё 14 комментариев
Добавить комментарий
4 Ответов
Выбранное решение
Hey Alain,
Unfortunately you can not uninstall Google play that easy, but luckily their isn't a need for that!
Google play may stop working due to;
Not enough memory on your device,
Your Date and time may be inaccurate.
I suggest checking both of these things, Another thing you can try doing is opening up your settings, applications, Application's Manager, Find Google Play. Their should be a 'delete cache' button. This deletes any miscellaneous properties and will not cause any harm. Once doing so go ahead and restart your phone and try it.
Hope this helps :)
Update (11/15/2017)
If that doesn't work, their is a clear data button, this removes your account info etc off Google play, But can be re-instated back on once you open up Google play again.
Now their is also a uninstall updates button, this restores the application back to its default factory settings. You could do this and go into the old version of Google and it should update itself.
Hope it helps!
Был ли этот ответ полезен?
Счет 24
14 Комментариев:
Hey Alain, Just coming back to check up, Just wanted to know if this worked, if not. How can I help?
из
Hi Brayden, It did work! I uninstalled all updates and defaulted to the factory setting. It works fine since then. Thanks for your help.
из
Awesome, Glad I could Help!
из
I had the same issue and uninstall updates did the charm. thanks much for the post.
из
I am unable to open any pages on my Galaxy Tablet i cannot get to settings or any other app,, any suggestions please
из
Показать ещё 9 комментариев
Android comes with native Download Manager app that is used by Google Play Store and Google Play Services to download updates for apps as well as the Google Play itself. But some apps with download option modify that functionality by disabling Download Manager, which causes Google Play to stop.
Счет 10
3 Комментариев:
Deleting data from download and download manager worked for me , thank you
из
Yeah, gotta be careful with some apps and there permissions.
из
Thank you for your help i wouldn't have made it with out you your kindness was and patient was what I reedit thank yo bye
из
Ok so I was haveing trouble but what I did was I disabled the app then enabled and it worked perfectly
Счет 4
5 Комментариев:
Yeah, some bugs happen, especially with older deices that aren't able to support the newer versions of the app.
из
What do you do if you can't disable the app?
из
Disabling and enabling again didn't help.
из
In my moto G3 mobile the window 'unfortunately the Google play services has stopped ' is not closing. The phone is not giving any response. How can I solve it.
из
GamerGeeks shows all MOD APK games and premium apps for Android devices. You can find and download all mods without viruses for more @thegamergeeks
из
i think i have a huge problem i wish u could help me . ma old tab 2 (7.0 version ) doesnt work i dont know why the google play swont work (send a message :unfortunately , the google play store has been stopped) even the browser google or any app wont work :(((( i tried to default factory settings the tab and even that doesnt work .
any solution ????
thank you
Счет 0
1 Комментарий:
Hey @spartoxff Ensure the tablet is up to date and the time zone/region is correct.
I've had issues in the past where it was just down to the region set incorrectly.
Let me know how that goes.
из
Добавьте свой ответ
Alain Tessier буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 42
За всё время: 159,463
