Четвертое поколение iPhone. Ремонт довольно прост, однако переднее стекло и ЖК-дисплей необходимо менять в сборе. GSM / емкость 8, 16 или 32 ГБ / Модель A1332 / Черный и белый. Эта страница поможет пользователям в поиске неисправностей, ремонте и получении помощи по iPhone 4.
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
Это хороший вопрос?
Счет 3
Добавить комментарий
3 Ответов
Выбранное решение
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
Был ли этот ответ полезен?
Счет 5
3 Комментариев:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
из
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
из
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
из
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
Счет 1
I just broke the !@#$ out of hte back of my iphone doing htis
Счет 0
Добавьте свой ответ
Ryan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 9,547
