Motherboard components change help?
Im looking at changing the following chips between two matching iPhone 6s.CPU chip, Qualcomm baseband ic, nand memory chip, my question is after getting them both finished will i need programming tools? For each chip? When i first researched this it looks like you can just switch them and turn them on. Now I'm being told differently. Also I was just told I'm missing a piece. Yes this is for refurb of phones with iCloud activation lock. Clean imei not stolen
Это хороший вопрос?
2 Комментариев
Based on what I see in the video he has the special equipment to see the chip turn on? And apart from that they were pretty regular tools based on what I've seen. Why are people surpressing the info
из Kramer
No one is suppressing any info. There are tons of videos showing how to micro-solder NAND's, Baseband and even CPU's. There are folks in Asia doing this daily using low-end tools and working on denim-covered "workbenches".
However, if you think this is straightforward...then go ahead and try it. Just make sure to report back to tell us how it went :>). You might want to read through this Q&A (Replacing fpc connector because touch screen is not working), especially the comments where this very issue is brought up and @arbaman bravely admitted that his first attempt on a much easier repair did not go well at all (with pictures to boot!).
из Minho
