HP LaserJet CM1415fnw — это многофункциональный цветной принтер производства Hewlett Packard.
printer not working rightaway
when I ask my printer to print with WiFi it can take a long time to print.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Depends on your router, distance between router and printer, driver settings. There are lots of factors that can be part of that problem. Try to connect printer directly to PC wait for driver to install and print some documents. After that - repeat print same document - through wi-fi. That way you cut off driver setting.
All the rest - can be caused by your network. But I'm thinking - that your printer is stuck in calibration longer then usual before prints comes out. And that can be part of your problem as well.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ken Wismer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 34
За все время: 299
