Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
Whole system shuts off
Hi there I'm stuck.
I have a acer v3-571g
My laptop seems to just die after about 3 mins.
I managed to run a temp program and watch it die at 60 degrees. (nothing majorly high) I can feel the fan blow slowly warm air it doesn't spin up like crazy to try and cool. I've changed hdd incase it was that. No luck.
It happened with and without battery.
I'm really stuck. Please help. Thanks in advance
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
A good temperature monitoring program like Speedfan (http://almico.com/speedfan452.exe) will give you several temperatures in addition to the hard disk. I'm not sure at what temperature a system will shut down, but 60 is certainly on the warm side.
I think you need to disassemble it in order to clean the fan properly. There are several guides online but unfortunately not here on iFixit. (Perhaps you could write one when you've finished!) You have to take the motherboard out to get access. Don't take the heatsink off the processor unless you have to, as you will need to reapply new heatsink paste if you do, and you may make it worse if you don't do that properly.
With the motherboard out you should be able to separate the fan in its housing from the cooling vanes - usually there are several small screws and a piece of tape to seal the gap between the fan housing and the cooling vanes. If you find a lump of matted dust and fluff on the cooling vanes, that'll be your problem. Otherwise, or if it's no better, it may be worth renewing the heatsink paste. Get some of good quality and watch a few videos first to make sure you know how to do it.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
OK update;
I replaced the thermal paste and retested no luck.
I replaced the fan and retested no luck
Im going to replace the heat pipe next to see if that helps
It runs for about 4 mins first start then have to leave it for about 30 mins to be able to reboot.
из
Добавьте свой ответ
Adam Brooks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 1,038
