Asus G752 SSD issues - Reinstalling has Risks
So I have a G752VS
Problem is the NVME SSD isn't native with the motherboard.
If you stuff up installation, you basically brick your SSD and you cannot install Windows to it.
Problem is I do lots of stuff, and instead of cleaning all the problems or bugs up, I just reinstall Windows and start again.
Anyhow, I can't really do this without fear of losing my SSD's capabilities..
Is Windows Reset the same as doing a complete bare metal reinstall? Or are some things retained in the process?
To elaborate more.. when you do a complete reinstall of the OS, you cannot see the SSD drive when asked where to put Windows. You need to install a driver manually and it appears that sometimes this doesn't work, leaving you stuck.
Это хороший вопрос?
Счет 0
Добавить комментарий
