How to replace front glass?
I would really appreciate a guide on how to replace the front glass for my daughter's 2014 kindle. thank you in advance foe any help.
Это хороший вопрос?
Это хороший вопрос?
you are not telling us the exact Kindle that you need help with . The device you picked is the FireHD 7 and you can use this guide Замена дисплея Amazon Fire HD 7 (4-го поколения) for that
matthew santiago you will have to follow the above guide in its entirety. You then need a heat-source like a good hairdryer or a hot air gun at it's lowest settings to soften the adhesive that holds the touch screen to the frame. Soften it with the heat-source and remove the touch screen with same plastic tools like guitar picks etc. Check this video from 7:54 and proceed identically to it.
Был ли этот ответ полезен?
I am requesting info on repairing the glass, not the LCD.
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За все время: 806
1 Комментарий
This question is in the Amazon fire hd 7 section.
из matthew santiago Поделиться
