Nintendo DSi — третья итерация в линейке Nintendo DS, которая впервые появилась в Японии в конце 2008 года.
How do I fix unresponsive shoulder buttons?
Very simply, the L and R buttons on my DSi don't work anymore. I tried going to Nintendo about the problem, but they said it'd cost at least $50 to repair...and my system is long past its warranty. Will I have to take apart my DS to fix it?
Это хороший вопрос?
Счет 58
7 Комментариев
It may have been the yogurt or hot chocolate that got spilled on it, but one of my shoulder buttons is very unreliable. I fixed it by dipping the switch in isopropyl, but it was only temporary.
из
i took mine apart and sprayed a little WD-40 on the switches, i hope that works for at least a month.
из
YOU &&^&^$^ GENIUS! thank you :) x
из
BW-100 is perfect for cleaning buttons without disassembly. It’s non conductive and evaporates quickly. I definitely do NOT recommend WD-40 as it leaves a residue and doesn’t go away without cleaning. If you use WD-40, do so in small quantities and you should definitely clean up any residue and not leave it in your device.
из
You were right, i had this problem for many years and thanks to you i can finally play my games like the way i used to! Thank you very much again for your precious help!
из
Показать ещё 2 комментариев
Добавить комментарий
11 Ответов
Выбранное решение
I know this is an old thread but listen if you are having problems. Here's how I solved it myself with no help from Nintendo and a super easy method.
My bumpers have not worked for over 5 years. both L & R. when I press R, it sounds like it has a broken spring while L sounds normal but also won't work.
Today, I tried to get them working (With Success) by first, mashing them really hard and fast and pushing down on them. After, I tried blowing in the side really hard just with my mouth. No taking apart. Then I kept mashing them again and on the home screen to test to see if the camera comes on when pressing L or R. All of a sudden, after blowing, it started to work every time. R still sounds and feels odd but works. I just have to press them harder than normal though but they work fine now!!
I was so happy after they started working. it has been years. I was unable to play soo many old games as they required the bumpers but now I can play them again just as soon as I get a new R4 card. I also updated the firmware after nearly a decade and now my current one is outdated.
Edit August 2022: Still glad to see this continues to help people. I have read all of the comments so far. As other people pointed out, there are potential risks involved to be aware of. This is mainly potential saliva damage. So Try not to spit into it and also do not overdo it. Personally, I would take the trade-off on an old device to get it fully functional again and mine still works fine after using this trick to this day.
Был ли этот ответ полезен?
Счет 200
163 Комментариев:
Thanks much bran04don13, been having this problem for a few years but mashing the buttons PLUS simultaneously blowing for a good 2 minutes on on both sides removed the problem!
Remember to blow as HARD as you can on that tiny concentrated space (doubt that spitting will work xD)
из
WOW this worked! i couldn't believe it! thanks alot! now i can finally soft reset and play games which really uses the L and R bumpers alot!
из
Holy molly ! I tried it and it actually worked ! I am baffled ! Thanks mate you're the best ! !
из
%#*@...I was super skeptical, after trying it a couple times, I was pleasantly surprised to see that it worked. Thank you very much. Now, I won't have to try to return it or get a different system.
из
IT WORKED THANK YOU SO MUCH, mine hasn't worked in over 6 ears thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
из
Показать ещё 158 комментариев
You could try to blow on the indentations along the right and left side of your DSi system with force. Do so again on the top. This issue is likely caused by dust or other debris that may have gotten into the release trap and pressure-sensitive button. Or you could use a can of the duster for electronic equipment that is available in most department stores. Some more info here http://www.ehow.com/how_4737318_nintendo... and even some video on here http://www.youtube.com/watch?v=5K3W9sbwX... good luck and let us know how it is turning out.
Счет 16
6 Комментариев:
that is a bad way because i did that and my ds's sound went out
из
I know this is a super old thread, but those whose systems are breaking is because the saliva from their mouth is getting into the system. I would recommend using the dust remover that is mentioned in the comment, as you won’t be damaging the system. If you don’t have any, then you can use the air from your mouth but make sure your mouth is super dry.
из
@exodous it ok happens to all.....I think
из
It works thanks
из
PLEASE DONT BLOW ON YOUR TRIGGERSSS( well according to me you can I f you want) so a couple years ago I was playing mario kart on my DSi and the right one just stopped, then a month later the l one stopped.
I couldn't play most games anymore so now about a few days ago I looked up a tutorial and it said "keep mashing/pressing your shoulder buttons really fast and blow on them" I tried it and It worked!
But only for 5 days, so when I was playing mario bros I was seeing if the shoulder buttons did anything but they didn't. I new I had to open it up so I did that, got isopropyl alcohol(for the electronics) and cleaned the inside of the L and R buttons the left one was fine but the right one didn't so if they are really REALLY bad...just get a new DSi.
Hope this helped!!!
из
Показать ещё 1 комментарий
Nonono. Do not blow on the buttons.
At first my L button went out and I would blow on it and it would be fine.
But recently my R broke and right after I did that, my DSi would turn off.
Then when I would turn it back on, it would shut off again, or the top screen would flash out.
Please don't
Счет 3
3 Комментариев:
i had the same problem about a year ago on my other dsi,so i'd rather not to do it myself
из
I did that on my 3ds xl as well and it broke playing mario party
из
that's probably because you accidentally blew in some spit by mistake short circuiting your power button
из
my dsi r and l bottons haven't wont for 2 yaesr i tryed to watch some videos on the internet and i didn;t help at all so i just fould this website becasue my friend told me and this website will work for my dsi r and l bottons.
Счет 1
1 Комментарий:
Take some isopropyl alcohol and drip a liberal amount into the crevices of the button.
из
i would HIGHLY Suggest (yes i hate bring old threads) is you HAVE TO take it apart.
but just to get the back...cause i just almost killed my DSI using the suggested answer (got my L&R buttons "Working")
use just compressed Air to get the dust out! when you do this you can also bend the buttons up some soo they can have better contact. and also get a hard deep into it if you have to press hard
reason is i wanted to play some DS games not on my 3DS as i tried to fix it now....reason cause i'm restarting my Pokemon saves on the DS and i needed a trade thing...since i have a Pro Tech Tool Kit i can just open it up...
if you dont...try the Most Helpful Answer...but BECAREFUL OF L OR R!!! that is the side of the ribbon for the top screen....that jangles...no top screen or sound!
Счет 1
if you take it apart be extremly careful, i lost my "r" button due to riped wire, but in side your ds/dsi is this little tab that plugs into your system and this may be unpluged because of drops or loose, but take a narrow metal nail file and clip it back in it solves the problem, but becareful like i said, i completely lost r
Счет 0
My buttons worked but the R button was mushy. The dsi is absolutely prone to ribbon problems I swear.. anyways, the button is clicky after blowing into it like it used to be (yay) but it did giggle the top screen ribbon slightly and caused the top screen to go all white washed with scan lines. Moral of the story, I hope you know how to take these apart if you blow into the R trigger too hard.
Счет 0
There are small buttons underneath the covering. If you don't want repairs, just take the coverings off and be careful that you don't get any gunk inside, because the motherboard will be peeking out.
Счет 0
After taking apart, blowing into the buttons and applying a small piece of plastic to have more grip, with no success. The only way to get it working was just by using regular 96% alcohol with a cotton swab, cleaning all around with and ensure alcohol got inside the buttons. After that, just used compressed air to take alcohol from inside the buttons and now works like new!
Счет 0
What about contact cleaner it’s specifically designed to dissolve dust and debris on electrical contacts and it doesn’t ruin stuff
I use it to get my 64 controllers working when I buy second hand ones
Счет 0
I started having issues with my R today. It was for some reason only having a 1% success rate on registering clicks dispite the console being in pristine condition. Had to take off the back panel and remove the R button. I then spritz'd it a few times with isopropyl alcohol till the surface of the switch was well dosed. Then sopped it up and clicked the switch about a dozen times with a cotton swab to clean it up. It appears to be working after that thorough cleaning. My electric air duster did nothing to remedy it. It's best to take it apart with the guide. You only need a small Philips head and a plastic pick or thin card for the disassembly.
Счет 0
2 Комментариев:
Soooooo... it sounds like they fail because dust and other debris accumulates in the sensor and stops the input from registering. The question is, how does the debris get in there? I mean, I know it's possible, or if not, at least somewhat possible, but I just don't see how enough could get in there to cause a problem in the first place.
из
the sides of the buttons are open, dust can go right down into the sensors
из
Добавьте свой ответ
Ari Rockefeller буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 33
За последние 7 дней: 317
За последние 30 дней: 1,333
За всё время: 222,915
