Информация по ремонту и руководства для iPhone 6S, выпущенного компанией Apple 25 сентября 2015 года. Модели: A1688, A1633
Inaccurate GPS while moving
Hello,
I bought used iPhone 6s in perfect condition, but I've got problem with it. I'm a runner and I use GPS trackers a lot. I tried to change the app from Endomondo to Runtastic but there was no effect. My tracking is full of waves and it is "rounded". I installed app called GPS Status. It shows sometimes my position with 10m accuarcy but the most of the time there is +-65m and even if the phone is not moving it shows speed occasionally. What should I do?
Это хороший вопрос?
Счет 0
Добавить комментарий
4 Ответов
Hello,
i would advise you to swap out the internal antenna it's weak and internal antenna isn't so expensive so go for it. Guide and every thing will be down below. If you don't have tools required to oppen up your device i will also post that down below.
Internal antenna:
iPhone 6s Wi-Fi Diversity Antenna
Tools:
Pro Tech Toolkit
or if this is too expensive you should buy this next tools:
you can find this tools at this link but just scroll down to tools:
iPhone 6s
EDIT:
Forgot to paste the guide link so here it goes:
Замена верхней левой антенны Wi-Fi iPhone 6s Plus
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions. Изображение
Товар
Pro Tech Toolkit
$79.95
Replace the Wi-Fi Diversity Antenna compatible with the A1633 and A1688 model iPhone 6s smartphone. Fix unreliable connectivity to Wi-Fi signal. Изображение
Товар
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Ok, thank you very much. I will tell later if it work.
из Поделиться
I see you are new to this site so if my answer is correct you chose my answer for solution. If not you can wait for someone else to answer. And if some how good point you can up vote it. Hope it works.
из Поделиться
Hello,
I've changed the diveristy antenna, but it didn't help. The GPS is the same inaccurate as it was. Should I check something more?
Счет 0
Замена шлейфа антенны iPhone 6
Счет 0
GPS tracker and network
Счет 0
Добавьте свой ответ
Michał Wijata буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 14
За все время: 1,487
