cracked look in screen
my laptop has a layer that looks cracked not top layer it was leaned on
Это хороший вопрос?
Это хороший вопрос?
So your glass is okay but your LCD is cracked? Time to get a new display they are relative inexpensive http://www.lcdscreen.com/ppc-series-acer...
Был ли этот ответ полезен?
If you are not planning on replacing an LCD connect an external monitor using a VGA cable for output or if your TV has a VGA connector then you can even get the output on your TV.
You can buy a replacement LCD from eBay and take it to a local electrician and have it replaced for you
Good Luck.
Hopefully the OP fixed it within the last 2 years ;-)
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 2,104
