Третья модель в линейке компактных камер Canon с мощным зумом. Выпущена в феврале 2006 года.
LCD screen cracked. Replacement process?
The screen on my camera is cracked.
The screen will not come on at all right now.
I would like to replace it.
I found the blow-up diagrams but is there a correct process?
Do I also need to replace the Back Light Unit?
Thank you in advance for your help!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@nanaburt yes there is and all you have to do follow it in sequence as outlined in this document S3-Disassembly.pdf
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Thank You oldturkey03. I have the diagrams, Can I start at the point of taking the LCD cover off (after removing the battery) or do I have to remove the screen at the hinge before taking the cover apart?
из Поделиться
... also ... are there any precautions on where I should NOT touch as I remove the PBC Assembly as I need to re-use the current one if possible.
из Поделиться
@nanaburt this does look complex but at this point I'd follow the individual steps as they are outlined. Stay away from the flash cpacitor since it does pack a punch. You should always discharge that one before working on a camera. I do try to not touch all over the pcb but there is only a small chance to either shorten things out or cause damage due to static electricity.
из Поделиться
Добавьте свой ответ
Gale буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 22
За все время: 618
