Note keeps on crashing!
Note app keeps on crashing whenever I try to make a new note or deleting a note. I tried everything (resetting the settings, holding down the power button and home button at the same time until apple logo appears etc etc). Even when I try to sync my notes in itunes, the itouch shuts down itself, disconnecting from the computer. Please help, there are a lot of important stuff in my notes and I wasn't able to sync and back them up
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Hmm, I guess from it's age all you will be able to do is to back it up. Then if you were able to get a full back up on to your computer.
Press and hold power and home buttons while it is still plugged into the Computer.
Once it shuts down and you see the Apple Symbol, release the power button and continue holding the home button.
Your Computer should have a message pop up saying it found a device in recovery mode.
Restore your iPod, and leave it plugged into your computer, then as it asks you to set up the iPod from the welcome screen, press restore from back up.
This should fix your issue.
Был ли этот ответ полезен?
Счет 0
I faced same kind of issue but fixed by rebooting my iPad and following this solutions https://www.indabaa.com/apple-notes-app-...
Счет 0
You can check the solution here http://aaaccessory.com/
Счет 0
Добавьте свой ответ
Youdontneedtoknow буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 23
За все время: 421
