Операционная система Apple для настольных и портативных компьютеров Mac.
New hard drive will not format
Installed a new debate 500gb 7200 rpm 32mb cache SATA SSD Hybrid hard drive on a mid 2009 MacBook pro unibody. First question the screen is jumping with horizontal lines flashing different colors.
Problem 2: when I boot from original 10.6 disk and go to the disk utility to partition and format the new drive it says it is shows the new drive I select the single partition mac journaled and name it Macintosh hd and select apply. The status bar says unmounting disk it barber poles for a minute or so then give an error box that says "partition fIled with this error: POSX reports: the operation couldn't be completed cannot allocate memory
Help
Это хороший вопрос?
Счет 1
2 Комментариев
I can't locate a "debate 500gb 7200", please give specifics on this drive.
из
Sorry it is a Seagate 500gb ST MOM 7200RPM SATA/SSD Hybrid XT
из
Добавить комментарий
3 Ответов
Выбранное решение
I know this post is old but I was having the same problem with my 2009 MBP and thought others may be too. Orignal HD quit and I couldn't boot under any mode. Oddly enough when I disconnected the HD and plugged it back in, it fully booted before crashing, then back to the original failure to boot every time after. I bought and installed a new SSD but wasn't able to format/erase due to the same "cannot allocate memory" error using Disk Utility or Terminal. After playing with the SATA cable a bit just to make sure it had good connections I was able to format the drive and install 10.6 with no problems. I think that would explain why unplugging the original HD and plugging it back in allowed it to boot once. It's been a day since I installed OSX on the new SSD and I haven't had any problems. I'm going to replace the SATA cable just to be sure, but I think this may be the problem for others with older MBPs who are trying install a new drive.
If you're having this problem trying formatting the new HD via a USB/SATA cable (instead of in your macs HD bay) before you return the drive or give up. Worst case you'll rule out the SATA connection, but this worked for me.
Был ли этот ответ полезен?
Счет 2
Наиболее полезный ответ
This solution may work for you: http://reviews.cnet.com/8301-13727_7-104...
Счет 2
this happens when your flat cable stops working. try conecting thru an USB adapter to confirm
Счет 0
Добавьте свой ответ
Jim Young буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 37
За все время: 34,412
