Пятое поколение Volkswagen Jetta было представлено в январе 2005 года.
Why does my engine cut out while driving?
I do have a transmission issue (3rd gear incorrect ratio)
But while I drive my engine cuts off stopped at a stop light without warning and can turn it back on without any issues.
When it shuts down a battery symbol is shown but once it turns back on it goes away.
Can my transmission be the cause of this or would it be something else?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Really need to scan the car for the best answer. However, if it cuts out and shows a battery symbol the best place to start would be the charging system. Need to look at both your battery and alternator to see if A. your alternator is putting out enough charge to keep your battery topped up, should be around 14V. Also if your battery is still in a good enough condition to accept a charge.
A scan though, would be your best bet, as VAG cars can be somewhat temperamental.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Jose буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 45
За все время: 1,246
