Stylo 2 (номер модели LS775) — второе поколение серии Stylo производства компании LG, выпущенное в апреле 2016 года.
Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
Это хороший вопрос?
Счет 3
3 Комментариев
I have to same problem it say my headphones are in but they are not
из Поделиться
It shows headset logo on screen and sound is not working
из Поделиться
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
из Поделиться
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
Был ли этот ответ полезен?
Счет 7
9 Комментариев:
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
из Поделиться
Thank you! This worked.
из Поделиться
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
из Поделиться
It worked for me too!!!
из Поделиться
and anotha one!!!!
из Поделиться
Показать ещё 4 комментариев
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
Счет 1
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
Счет 1
2 Комментариев:
thanks so much i try this way my problem was resorve .
из Поделиться
The push and click worrrrrked! Thank you so much!
из Поделиться
Счет 0
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
Счет 0
Добавьте свой ответ
Geneva Campbell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 21
За все время: 13,184
