ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
ΠŸΡ€ΠΈΡΠΎΠ΅Π΄ΠΈΠ½ΡΠΉΡΡ ΠΊ сообщСству Ρ€Π΅ΠΌΠΎΠ½Ρ‚Π½ΠΈΠΊΠΎΠ² - Π‘ΠΎΠ·Π΄Π°ΠΉ Π°ΠΊΠΊΠ°ΡƒΠ½Ρ‚
Π‘ΠΎΠ²Π΅Ρ€ΡˆΠ΅Π½Π½ΠΎ Π½ΠΎΠ²Ρ‹ΠΉ Passat, созданный Π½Π° ΠΏΠ»Π°Ρ‚Ρ„ΠΎΡ€ΠΌΠ΅ B5 ΠΊΠΎΠ½Ρ†Π΅Ρ€Π½Π° Volkswagen, Π±Ρ‹Π» Π²Ρ‹ΠΏΡƒΡ‰Π΅Π½ Π² 1998 Π³ΠΎΠ΄Ρƒ Π² Π‘Π΅Π²Π΅Ρ€Π½ΠΎΠΉ АмСрикС.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 0
1 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ:
This question was migrated from https://meta.ifixit.com/Answers.
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
2 ΠžΡ‚Π²Π΅Ρ‚ΠΎΠ²
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 0
Air flow and throttle show a short circuit .wiring okay
ΠΈΠ·
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Π‘Ρ‡Π΅Ρ‚ 0
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
Stephen Ryan Bearden Madison E Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 1
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 7
Π—Π° всё врСмя: 1,727
