always SIM Card Removed
Dears
I found the below error message always.
SIM card removed. The mobile network will be unavailable until you reset with a valid SIM card inserted. RESTART "
When I press restart it will work again for a while but then goes off again - typically about 10 times a day. Sometimes I have to restart twice to get it going. I have taken out the SIM & cleaned it but it makes no difference.
Any ideas as to what I can do?
best regards
Girma G.
Это хороший вопрос?
Счет 0
3 Комментариев:
just to Add
Mobile mark =====LG flex
Model#========= D958
из
Perhaps check for updates?
And have you tried using the sim card in another phone (or device that supports it)?
If that doesn't help, try a force reboot with and without the sim card inserted.
Note, only insert or eject the sim card when the device is powered OFF!
из
sorry for my bad English and many thanks for your valuable comment, but i tried all the above recommended solution but no difference. sometime the network is OK during using internet like Facebook, Viber and other social media. but after a certain minutes, the network is lost and again and again restart the phone. please help me if you have any other solution
из
Добавить комментарий
