My laptop boot problem
It is saying that it is restoring previous version of Windows
It is restarting again and again
Please can you fix for me.......
Это хороший вопрос?
Это хороший вопрос?
Just download a windows iso file from any site or just click the link i have provided and make bootable pendrive with it. Use this USB to install new windows to your PC. Now you can reset all the things in your computer from start.
Был ли этот ответ полезен?
If you did not ask it to restore previous version, Windows is running into a problem with the version installed.
It could be a bad file, corrupt HDD, bad driver, or incompatible hardware.
It may be possible to boot into safe mode. If so, then you can try to run CHKDSK C:
That looks for and tries to fix problems on your HDD.
After that, you can try to run SFC /scannow.
That looks for corrupt system files and restores them if found.
Both of those must be run in a command window. Click Start button and type CMD then click on the answer.
If you can't boot into safe mode, the only option is to reinstall Windows as mohit pointed out.
However, if you have unbacked up files on your HDD, you will need to remove the HDD and connect it to another computer to remove them b4 installing. That may or may not be possible if there is a more serious issue with the HDD. If so, you may need to replace the HDD.
Then back to your computer and do a clean install. An update install might work and would negate having to reinstall all your programs. It depends on where the problem is. A problem in the registry might be carried over in an update install.
If you are unclear about Windows clean vs update install, google it.
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 10
За все время: 923
1 Комментарий
Hi dawn tom
Are there any important data in it?
It could be OS issues (Crashed) or HDD issues.
Any symptoms or changes you had done or noticed before this happened?
I suppose the current windows is running on win 10 ?
из Augustine Поделиться
