How to replace radiator
how fixed water tank
Это хороший вопрос?
Here's a video on how to do it:
Был ли этот ответ полезен?
Did you check for any coolant stains around the base or seams of the radiator or around the radiator neck etc?
If around the base of the radiator you may have a leaking radiator core or if on the neck of the radiator, a faulty radiator cap.
Get the cooling system pressure tested to see if the leaks show up.
За последние 24часов: 1
За последние 7 дней: 18
За последние 30 дней: 75
За всё время: 9,394
5 Комментариев
what year is the santa fe
из Jimfixer
A 2012 Hyundai Santa Fe, have radiator leak, replaced top hose already, still leaking. Can't find a Youtube video for 2012 Santa Fe.
из lilirishpol
Just to know how to repaired
из Esam
How to fix or replace radiator
из Martin Caine
@Martin Caine
What is the year model of the vehicle?
What's wrong with the radiator?
из jayeff
