Четырехъядерный процессор Rockchip RK3288C, 11,6-дюймовый HD-дисплей с соотношением сторон 16:9 (1366x768), 16 ГБ eMMC, встроенная графика Rockchip® Mali T764, LPDDR3 МГц SDRAM, встроенная память 2 ГБ / 4 ГБ
Screen bent back too far
My toddler bent the screen back to far and something snapped and now the screen is completely black. I’m pretty good at diy but I’m wondering if anyone has an idea how fixable this is?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Without knowing the specific model I can only guess, but I would think the display cable connecting the screen to the motherboard has broken. With some care it should be possible to open up the laptop and check it to make sure.
The LCD screen guide for your laptop explains how to open up your laptop and find the cable (as it needs to be disconnected to replace the screen). In your case the screen will probably be fine.
Replacement cables can be bought online (I think I saw it in the ifixit parts store, although you may be able to find it cheaper elsewhere).
If you want to make sure the computer itself is still fine, find a tv or monitor and connect your computer to it using an HDMI cable. if your screen is visible on the external monitor, then the issue lies either with the cable or the screen. Since the screen did not take a hard hit the cable is the most likely bet.
Happy fixing!
Был ли этот ответ полезен?
Счет 0
I bent my Chromebook HP screen back too far and now it's really dark but it still works perfectly fine but the screen is just really dark how do I fix that ?
Счет 0
Добавьте свой ответ
aflann1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 18
За все время: 2,324
