Touch Unresponsive even after replacement
My phone fell out of the holder into a cup of water while driving. Only the bottom half fell in. I got home and cleaned the inside with rubbing alcohol, put it all back together but the touch was completely unresponsive. I ordered a new screen and digitizer replacement, got it all together, same exact problem, but the screen looks great now. (The water dropped one had water bubbles) Non of the contacts look damaged, everything is plugged in.
The weird part is, if I turn the screen off, then turn it back on, the touch will kind of work for like 1 second, then stop completely until I turn the screen back off then try again.
Это хороший вопрос?
Счет 0
Добавить комментарий
