Repair guides and support for tablets made by Hipstreet. These tablets run on the Android OS.
Display my tablet on projector screen?
Hi guys,
Need some help.
I want to connect my Hipstreet Hyperion Tablet to a projector (VGA port).
I have purchased a mini USB to VGA converter lead, everything seems to be connected up fine but my projector fails to display my tablet on screen. I basically want to mirror my tablet onto a projector screen.
Please help! Thank you .
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi David,
If the projector is just displaying a black screen, it's possible that your tablet simply doesn't have enough processing and graphics power to send the display over to your projector. I would check to see if your tablet at least has Android 4.4.2 on it. Google states that's the oldest version that will be able to cast its screen. Try connecting it to another source, such as a TV or an old monitor with VGA connectors. If those work and the projector does not, then it could be something with the projector that needs set or isn't compatible with the tablet.
Best of Luck,
Drew.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thanks for this.
When I search on the projector for the source my tablet does no appear at all (VGA 1, no source found).
The android tablet is a 4.4.2.
Head ache but I will keep trying.
Thank you for your help.
из
Добавьте свой ответ
David буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 512
