Информация по ремонту и руководства для обновленной версии Retina MacBook 2015 года, выпущенной в начале 2016 года. Модель A1534 / EMC 2991
No output devices found
Hello All,
I recently installed a new display assembly on the macbook and had some issues. I finally got the display working when i realized that the audio cable was in backwards pins side up instead of down (dumb mistake). When i put everything back together I was worried that the sound may not work. sure enough its not working. not internal speakers are seen by the computer. the error is no output devices found. I reset the PRAM. and even reinstalled OSX. I have checked all my internal connections to the logic board. i ran a hardware diagnostic and its not seeing any issues. I am worried that the audio board and the cable might be fried... any ideas would be awesome.
PS. plugged in headphones and no go.
Это хороший вопрос?
Счет 3
Добавить комментарий
1 ответ
I know this question is old but you most likely tore the audio board flex cable when you disassembled the machine
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Yelitza rodriguez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За все время: 742
