Информация по ремонту смартфона Sony Xperia X, анонсированного в феврале 2016 года и выпущенного в мае 2016 года. Этот телефон входит в серию смартфонов Sony Xperia X.
Phone Screen not working (no touch)
Hello!
A while back, I dropped my phone in water and immediately disassembled it to dry it off. The symptoms were a screen that either worked perfectly after reboot and then turned black every time the screen was turned on, or a perfectly functional device except that the digitizer did not work. So, after reading some "advice", I soaked my screen in 91% alcohol, leaving permanent marks. Then, I soaked the logic board in alcohol with a vibration assist from a washing machine. The logic board seemed to be fixed, and being a perfectionist, I tried to go a step further by using a food dehydrator to dry the alcohol marks out of the screen. However, after a while of drying (of screen only, vacuum sealed into a container with silica gel and dessicants), the screen digitizer does not work anymore.
My question is this: is the problem with the screen or the logic board? I noticed that some antenna contacts were slightly bent out of shape, but I am not sure what happened to the rest of the board. There doesn't seem to be corrosion. Keep in mind that after the laundry machine vibration, I took the board out of alcohol, but after I discovered the screen issues, I put it in for around 24 hours.
If needed, I can send photos.
Это хороший вопрос?
Счет 0
1 Комментарий
OK, I am actually out of state right now, I will post once I get back. Yes, I will order the replacement screen later.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@froggr123 just add your pictures to the question. Use this guide Добавление изображений к существующему вопросу for that. Going by your description alone it sounds like the issue is with your display assembly. I would go ahead and replace that. If the error is on the motherboard, then there is only a slim chance of repair. You would need a schematic which is not available. Sony simply does not have those anymore. Replace the screen and re-evaluate Замена ЖК-экрана Sony Xperia X
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Sony Xperia X ЖК-экран Изображение
Инструкция
Сложность:
Умеренно
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
@oldturkey03 I will upload images tomorrow (just got back from out of country). Will order screen later from Amazon. The WitRigs screen does not have a frame, and I don't want to detach the frame for safety reasons. Hopefully the screen is legit. Thanks!
из
Добавьте свой ответ
froggr123 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 26
За все время: 519
