11,6-дюймовый ноутбук, созданный с прицелом на доступность. Chromebook 100s оснащен дисплеем с разрешением 1366 x 768 и аккумулятором, обеспечивающим до 8 часов автономной работы.
What can I try in this difficult case?
I recently received several important messages that came to me in Outlook. I almost immediately found out about it and clicked on one of the letters. But unexpectedly for me there was an error unknown to me because of which, I can not see the text of the letter. I've repeatedly tried to check the system block for viruses, but in my problem this did not lead to anything.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Since chromebooks normally cannot run outlook how is this possible? Maybe you meant to attach this to some other more generic Lenova windows laptop perhaps?
Был ли этот ответ полезен?
Счет 0
Outlook repair software is a utility that you can use in this case talk you how to repair outlook. It is highly recommended that you backup the damaged PST first as running the tool can irreparably damage the file.
But there are outlook repair tools that could aid you like Recovery Toolbox, Stellar Phoenix, DataNumen and etc. – they are most effective. Moreover there is new generation of instruments like Outlook Online Services.
• Quit the application
• Scanpst.exe is a hidden file so make sure that the 'Show hidden files and folders' setting is enabled in the folder options
• Click Start | Search, or Find and type 'Scanpst.exe' in the Search box
• Double-click to open the file and browse to the location of your damaged archive.pst
• Click 'Start' to start the recovery process
• Try to open the file in question again. The corruption problem should not exist.
Счет 0
Добавьте свой ответ
EliJuarez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 394
