Western Digital My Passport Ultra — это портативное устройство хранения данных с интерфейсом USB 3.0 и емкостью от 500 ГБ до 5 ТБ.
Replacing hard disk reading heads
Hi there!
I have broken reading heads on my WD10JMVW-11AJGS0. Which model can suit with same reading heads to replace? Didnt find this model on amazon/ebay so im trying to solve by this way. Thank you very much!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you haven’t taken your drive apart STOP!
HDD’s are not something you can work on in a dust filled room! Even still this is beyond what an DIY’er can even attempt!
If you’ve already opened the drive you’ve likely killed it! Between the dust and finger prints as well as and moving the parts around you’ve likely damaged it beyond repair.
If the data is important to salvage you’ll need to send the drive out to a clean room and people who have the needed parts, like DriveSavers. Take a watch here on YOUTUBE: DriveSavers Recovery Tour
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I'm sorry, but dont have 2,500€ for this type of repair. I questioned about head compatibility. Thank you
из
Then it would be cheaper to get a new drive and forget what ever was on it.
из
Добавьте свой ответ
Lukáš Blažek буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 28
За всё время: 1,976
