How to correct this defect
''Is there a way to fix this device that's not charging and the display screen shows the start up screen that is looping? My device shows that the battery
Это хороший вопрос?
Это хороший вопрос?
I had that happen on a Droid Turbo 2 repair. Turned out, the owner had splattered soda on the phone and the keys were sticking down. The phone was looping because the power and volume down keys were stuck down. I used a soft art paintbrush and alcohol to clean the stick out. Don't wet the board and keys to much. Just a little at a time should do the job. If that doesn't work, you might have to do a tear down and remove the buttons from the device. Do be careful and always use a strainer in the sink so you don't have to order new keys.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 26
За все время: 243
