15,6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-бит, 4 ГБ ОЗУ, 500 ГБ HDD
Nvidia graphics stop responding
Whenever i install correct nvidia drivers for my laptop it shows an error Nvidia kernel is stop responding and successfully recovered, it shows error in every driver package i install. This problem is occurring a month ago when my laptop controller is damaged so i gave it to dell shop they fix it and since this error is coming bcoz of this camera and sdcard reader is also not working..
Pls help
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Only thing that would come to mind for me is the fact that ‘kernel’ is memory associated. However I dug around and found this quoted on another site.
‘Use Run and type regedit
HKEYLOCALMACHINE > SYSTEM > Currentcontrolset > control > graphicsdrivers. Right click graphicsdrivers, click new >Dword (32-bit) value. Modify the value to 8
What I did next was delete ALL of my graphic driver installed (the nvidia one). It will swap to the build-in one on your motherboard.
Then use driver sweeper, select nvidia, and let it erase ALL of your nvidia driver files.
I then re-installed the nvidia driver through the installation CD I got with the graphic card, and did NOT get any updates.’
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I tried it but i always shows error "VIDEO TDR FAILURE " and also i tried out the method u show but not workig is my gpu is damaged or something...
из
Добавьте свой ответ
Pratik Gahane буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 337
