Контроллер Dell VRC-100R можно определить по номеру модели: 536-BBBS. Это Bluetooth-контроллер виртуальной реальности первого поколения, выпущенный в октябре 2017 года.
Fixing the trigger on the WMR Controller?
The trigger on my right controller is stuck “pushing in” when I am in VR. I have tried to disasemble the controller to see if there is anything wrong with it, looks like it’s missing something. What could it be missing? I don’t want to disassemble my left controller needlessly to see if it’s missing something.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Ok…well apparently ifixit thinks my answer is spam. I’ll try one last time:
I think I may have the same issue, and I fixed it. I followed the ifixit guide for doing a touchpad replacement (apparently if I link to that tutorial, this post gets marked as spam, so you’ll have to find it yourself), through step 7, removing the back panel, which contains the trigger. In my case, the small metal rod that holds the trigger in place and allows it to rotate had slipped out of the hole on one side. I wiggled it back in place, and after putting everything back together it worked. It looks like this rod could easily slip out of place. Not sure if this is the same issue for you, but I hope it’s helpful. Best of luck.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
NO PE буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,107
