Аккумуляторный детский электропоезд «Паровозик Томас» с путями.
Not working at all
I have just been given this by my sister. I have had the train on charge for few hours but nothing no led, music, movement, just nothing all the components and connections look OK. How can I find the issue to fix the train. Thanks
Это хороший вопрос?
Счет 0
3 Комментариев
Hey, Kelly. Do you have a multimeter?
из Поделиться
Hi yes I do own one
из Поделиться
It is working for music but not moving
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Here's a teardown of the train. With the charger unplugged, set your multimeter to DC Volts and measure the voltage of the battery at the battery terminals. It should say on the side of the battery what the voltage is supposed to be. If the battery measures the correct amount, measure the voltage again with the black lead on the negative battery terminal and the red lead on the far end of the red wire. I would think it terminates at the back of the switch. If there is no voltage there then the in-line fuse is blown and will need to be replaced.
Детский электропоезд Thomas — схема системы и компоненты
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kelly Kennedy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 17
За последние 30 дней: 54
За все время: 2,658
