PlayStation Vita второго поколения, серия PCH-200x, обычно называется PS Vita Slim или PS Vita 200x. Продажи начались в Японии 10 октября 2013 года, 21 марта 2014 года в Европе и России, и 6 мая 2014 года в США.
PSV - charging issue - troubleshooting ideas
Hello,
I recently bought psv slim on ebay. Visual everything looks fine and in good state.
Issue is that battery is almost empty and if you plug usb to charge (from electricity outlet with phone charger, laptop usb or power bank (already tried different usb cabels)) it’s not charging at all while psv itself on.
If you turn off the psv then it charges for about 10 minutes (always the same time) and then you can use console for some time. If you try charge longer, orange light do not show up. If you unplug and plug again the usb it shows for about 50sec and turn off (the orange light). And it’s always the same time. Old owner told me that he tried to replace batteries, but I am thinking to do this also.
I dissembled unit and find nothing unusual inside, everything looks in tact without any trash or visual damage.
PSV version is 3.65
It’s really strange that charging time is the same every time.
I tried to reset factory settings and also unplugged the battery for some time to perform physical reset.
Charger port itself looks intact and in good state on outside and motherboard side (visually) .
Maybe some overheating or voltage security measures stops charge?
Could any one suggest what else I can try to fix this?
Thank you very much :)
Это хороший вопрос?
Счет 2
1 Комментарий:
I also tried an official charger.
Same, you can see orange light for some time and it disappears. I am not sure if a battery charging at all. Maybe something wrong with the motherboard itself?
Would be interesting to check resistors with a multimeter, but I have no idea what discrepancies should look like. Also, just in case I cleaned motherboard. Any other ideas what to check?
из
Добавить комментарий
2 Ответов
cut it off and cut it back on
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hi, what do you mean? To cut it off the micro usb charging port? Or unplug the battery?
из
Hello, are you able to measure 5V on board behind the power connector?
Счет 0
Добавьте свой ответ
Aivaras буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 3,379
