Canon AE-1 — это 35-мм зеркальная пленочная фотокамера (SLR) со сменными объективами.
How to replace Battery contacts?
Hi!
I bought an old A1. It doesn‘t fire. I think it´s because the battery contacts corroded. I already tried to clean it with alcohol but no chance. Is there a possibility to get to the battery contacts. Maybe to replace them or to remove it and put it into alcohol overnight.
Greetings
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Alcohol is not what I would use as it won’t cut through the battery corrosion. What you need is white vinegar use a cotton swab (Q-Tip) dipped in the vinegar and hold it against the contacts. You also need to flush the vinegar with water using the same approach using a wet cotton swab.
The bottom contact has a spring to push it up to make contact to the battery if this is not working you’ll need to replace the battery holder. Its a bit of work! Its not something I would recommend for a first timer as its a delicate job. Here’s the Canon A-1 service manual jump down to the exploded views at the end there you’ll see whats involved to get to it. You basically need to take the whole camera apart.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Lucas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 10
За последние 30 дней: 35
За все время: 2,891
