Процессор 1,4 ГГц или 1,6 ГГц / SSD 64 ГБ или 128 ГБ
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Это хороший вопрос?
Счет 1
11 Комментариев
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Добавление изображений к существующему вопросу
из
try a different dc in board
из
What’s that involve, is it doable myself?
из
the i/o board guide that trevor posted
из
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
из
Показать ещё 6 комментариев
Добавить комментарий
1 ответ
Наиболее полезный ответ
Two possibilities:
Most likely possibility: bad battery
Замена аккумулятора MacBook Air 11" конца 2010 года
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
Замена платы ввода-вывода MacBook Air 11" конца 2010 года
MacBook Air 11" (Late 2010) I/O Board
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports. Изображение
Товар
$29.99
Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V). Изображение
Товар
$57.99
MacBook Air 11" Late 2010 Аккумулятор Изображение
Инструкция
Сложность:
Умеренно
15 minutes
MacBook Air 11" Late 2010 плата ввода-вывода Изображение
Инструкция
Сложность:
Умеренно
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
andy hawkins буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За все время: 486
