1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162вопросов Показать все
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Это хороший вопрос?
Оценка 1
11 Комментариев
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Adding images to an existing question
из
try a different dc in board
из
What’s that involve, is it doable myself?
из
the i/o board guide that trevor posted
из
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
из
Показать 6 больше комментариев
Добавить комментарий
Добавьте свой ответ
andy hawkins будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 195
