MacBook Air 11" Late 2010 Battery Replacement
Выберете то, что вам нужно
    1. MacBook Air 11" Late 2010 Battery Replacement, Lower Case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, close your computer and lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 11" Late 2010 Battery Replacement: шаг 2, изображение 1 из 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Спросите у FixBot
    1. MacBook Air 11" Late 2010 Battery Replacement, Battery: шаг 3, изображение 1 из 2 MacBook Air 11" Late 2010 Battery Replacement, Battery: шаг 3, изображение 2 из 2
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Спросите у FixBot
    2. MacBook Air 11" Late 2010 Battery Replacement: шаг 4, изображение 1 из 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Спросите у FixBot
    3. MacBook Air 11" Late 2010 Battery Replacement: шаг 5, изображение 1 из 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Спросите у FixBot
Заключение
119 человек успешно провели ремонт по этому руководству.
21 Комментарии к руководству
This looks like an excellent how-to! Especially liked the location illustration of different length battery screws.
My only comment would be to have a tray ready to put the screws in - looks like they could easily be lost.
Leonard - Ответить Поделиться
Now my touchpad isn't working as well as before. Any ideas why?
todd rumaner - Ответить Поделиться
Dead on Accurate. Was very easy. I would change the rating from moderate to easy. The hardest part is getting the correct screw drivers.
Phil Blake - Ответить Поделиться
hello, is there any difference between A1370 (late 2010) battery part and a A1370 (2011) battery?
Carlo Mejia - Ответить Поделиться
I'm also wondering the same thing. Did you find the answer to your question? Thank you.
swj.sean - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 34
За последние 30 дней: 158
За всё время: 112,906
