Игровой ноутбук Asus G752VL-DH71 с диагональю 17 дюймов был выпущен в 2015 году. Его часто называют сокращенно — G752VL или G752.
audio port broken needs replace?
My Laptop has a broken audio port. If I plug my headphones into the headset port only One side works of the two headphones. This applys also to all other headphones I can see the plastic circle where the headphones plugs into has missing plastic and clearly some damage to the plastic circle. I need to replace this part how much can I purchase this for and how simple is it to replace a damaged port?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
From what I can see of this teardown video for a similar laptop, it might have to be that you have to replace the whole motherboard if you want to do it simply. There is a possibility of soldering and replacing purely the headphone jack component, but that’s out of my expertise area and pretty hard as far as I understand. I also haven’t found this part online anywhere. You can obviously bring it to a repair shop, but it would be pretty expensive. The cheapest alternative is to get yourself a pair of USB/bluetooth headphones. I have a laptop with a similar problem (except that the jack doesn’t work at all) and use USB headphones that work just fine.
Carpe Diem,
Minas
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
BOB MARLEY буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 24
За все время: 1,028
