Пайка — это способ соединения двух металлических деталей путем расплавления между ними другого металла-припоя. Существует множество видов пайки, но эта статья призвана научить вас основам электрической пайки.
Micro soldering start up
Hey all I am hoping there is someone out there who may be able to help me.
Recently I have been doing some research into micro soldering and would like to give it ago.
What equipment should i look at getting and what do I need to take into account.
Any advice would be great .
Thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Jessa Jones created a set of vids with IFIXIT a few years ago which are very informative! Here’s the first in the series Microsoldering with Jessa Jones.
Theres a lot to it! Between getting the correct gear, you need the skills to read and understand schematics and lastly access to the needed SMT components.
And lastly practice! Lots of it!
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
Thank you very much for this very appreciated.
из Поделиться
Yea .... Dan hit the correct word.... practice made perfect :D
из Поделиться
Hi claytonrablin
As for me, I had a Hot air SMD rework station and a temperature controlled soldering station.
Some would say for temperature controlled station, minimum 60W and above.
I prefer those stations to be separated, in event of a failure which will brick all usage. Encountered once when my temperature controlled soldering station heating element is bad. Lucky having the hot air, which is needed to solder the new heating element to the soldering iron.
Get good flux, desoldering pumps, etc.
A good start.. .Louis Rossmann videos...
https://www.youtube.com/watch?v=bVoBZqlv...
Update (01/20/2019)
Thankyou very much for this fantastic advice. What did you start off soldering ?
Update (01/20/2019)
Hi claytonrablin
Replacing QFP ethernet chip
Счет 4
Добавьте свой ответ
claytonrablin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 19
За все время: 789
