Samsung Galaxy Tab 2 10.1 — это 10,1-дюймовый планшетный компьютер на базе Android, относящийся ко второму поколению серии Samsung Galaxy Tab.
Upgrading to latest Android version manually
Hi there, I have an old Samsung Galaxy Tab 2 10.1 with Android version 4.0.4. Nothing is compatible with it anymore. How can I upgrade it to the latest Android version please? I have checked and it says no updates available
Это хороший вопрос?
Счет 47
7 Комментариев
Thank you so much
из Поделиться
Yes, you can upgrade to Android 6 Lineage 13.0, I have Samsung tab 2 10.1 with that
из Поделиться
Thank you so much Stephen. Much appreciated. How did you upgrade please?
из Поделиться
I have samsung tab 2 and playstore dont want to work
из Поделиться
I too have a Samsung Galaxy S - model number SM-T800 - running Android 6.0.1
When I check the updates it says it is up to date.
I would like to download an Application - Imaging Edge Mobile from Sony, so that I can check photos and videos taken on my Sony camera HX60V - It says the software is not compatible and I require Android version 7 at least to install the software.
How can I update the Android Version on my tablet?
из Поделиться
Показать ещё 2 комментариев
Добавить комментарий
3 Ответов
Выбранное решение
here you go
you need to install a custom rom
Android is modified by the manufacturer to work on their device, because every device has different hardware.
https://www.youtube.com/watch?v=7V5tZi5V...
Был ли этот ответ полезен?
Счет 8
4 Комментариев:
I have two Tab 2's - both at now too slow to use. Wanted to see if there was a way to update. the link above is marked Private.
из Поделиться
This was rubbish. The video whizzed through so fast and without explanation so that it was impossible to follow.
из Поделиться
the video has gone private
из Поделиться
As others have said, the video is private.
из Поделиться
If you go to [http:// https://forum.xda-developers.com/t/how-t...|XDA’s website] by clicking the link it should bring you directly to the how to’s of the tab 2. there is all kinds of valuable info on this site and if utilized will hopefully give you a better understanding of your gadgets. Good luck!
Счет 3
1 Комментарий:
Thank you William. That link was incredibly helpful!
из Поделиться
Try googling (samsung android tab 2 update ) and it will tell you how and where to go
Счет 1
Добавьте свой ответ
Jackie Barton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 71
За последние 30 дней: 225
За все время: 85,677
