Samsung Series 5 3G Chromebook. Этот ноутбук оснащен 12,1-дюймовым ярким дисплеем высокого разрешения с антибликовым покрытием, который идеально подходит для работы в интернете.
Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
Это хороший вопрос?
Счет 1
1 Комментарий
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
из Поделиться
Добавить комментарий
3 Ответов
Выбранное решение
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
Был ли этот ответ полезен?
Счет 5
2 Комментариев:
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
из Поделиться
robert clench, did you confirm this by checking the image of the teardown?
из Поделиться
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
Счет 1
1 Комментарий:
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
из Поделиться
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
Счет 0
4 Комментариев:
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
из Поделиться
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
из Поделиться
Yup, happens all the time ;-)
из Поделиться
how do u use the switch
из Поделиться
Добавьте свой ответ
William Greene буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 15
За последние 30 дней: 31
За все время: 11,568
