Defender 3.5 V8 oil pump
Why would a Defender 3.5 V8 un-prime iets oil pump while park uphill during the night?
Oil level is on mark
Oil pressure is fine will driving during the day and parked on a flat surface
Это хороший вопрос?
Это хороший вопрос?
Hi there!
If the oil is pressure builds up in like a second or two it is fine! On next oil change try an OEM or a more expensive oil filter. Because in the oil filter there should be a valve. Some cheaper oil filters don’t have a proper valve or its not existent. But as long as the pressure builds up fast it should be fine!
Hope this helps! Let me know if the pressure is not building up fast.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 913
