Nokia Lumia 730 — это смартфон на базе Windows, выпущенный в сентябре 2014 года. Он оснащен дисплеем с диагональю 4,7 дюйма, плотностью пикселей ~316 ppi и основной камерой на 6,7 Мп.
How to remove window 10 update temporary file.
I have a Lumia 735 Window Phone with 8Gb Ram and Window 10 always automatic quietly download partial update files and choked my built in RAM and cause it to run out of space. Check with Microsoft Forum and users are furiously cursing Microsoft but the question got no answer.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Finally I found a solution. To fool Window 10 Phone and make it automatically discard the temporary files, Just go to your Setting / Time & Languages / Date And Time and set your date to a year later. For example the current year now is 2019. I set it to 2020 and then shut down my phone and restart . The I go to Setting / Update & Security / Phone Update and click retry and it will return an error and purge all the temperary files.
I then shut down and restart again. voola! The Temporory file is gone and I regain the space.
However this is not a permanent fix and there is no way to turn off the automatic window 10 update and one day it will get choke again. just repeat the procedure and you are able to live on. Until you trash your window phone and move to IOS or Android. Hope this help to ease the temporary frustration,
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Burney Poh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 279
