Флагманский смартфон Samsung со стилусом и преемник Note8, выпущенный в августе 2018 года. Оснащен дисплеем 6,4 дюйма и встроенной памятью до 512 ГБ.
How to replace the screen without frame?
Hello, does anybody know how can I replace the cracked screen on my Samsung Galaxy Note9 without swapping out the whole frame? Also, Where can I buy Galaxy Note9 screen replacement?
Это хороший вопрос?
Счет 3
1 Комментарий
I am replacing screen without frame because I want to save money & time. I could find any good guides on the internet so PLEASE Help me.
из Поделиться
Добавить комментарий
4 Ответов
Выбранное решение
I’ll just use the same procedure as the Note8, It can’t be that much different anyway.
Был ли этот ответ полезен?
Счет 0
Наиболее полезный ответ
You will probably not save time if you but a screen without the frame. The process of taking the screen off the frame is a long one if you want to do it somewhat correctly. Yes you can just rip the old screen off but that creates a huge mess (lots of small glass pieces everywhere). The way to get the screen off of the frame is to use a lot of heat to loosen all the adhesive holding the screen onto the frame. When I say a lot of heat, I mean a lot of heat. You will want the device to be basically too hot to touch then use a playing card to start and cut all the adhesive holding the screen on. While you will spend a little more on a screen and frame combo, it will be a much easier repair and probably take you less time as you won’t have to try and take a screen off then put a new screen back on the frame.
Счет 5
Why are you wanting to replace it without the frame? Using a replacement screen with the frame is much cleaner. The suppliers I use only offer the screen with the frame. The screens are actual samsung screens because they come in a samsung service pack.
I use injured gadgets and mobilesentrix.
Счет 1
3 Комментариев:
из Поделиться
Have you found any suppliers without the frame? A quick search brought up suppliers charging about 40 to 60 dollars more for frameless note 9 screens. The repair time may actually be less with the frame. Youll only have to transfer the board and charge port connector which I've done on Galaxy devices before in around 30 min tops. I believe the lack of guides may indicate that the repair with the frame is the prefered method among repair shops and DIYers. Ill look around to see, if I can find anything.
из Поделиться
Has anyone found a video of replacing the note9 without the frame?
Счет 0
Добавьте свой ответ
Dinan Blueje буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 29
За все время: 5,712
