Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
iPhone 6S half backlight need solution
I got device which was having no backlight at all , after diagnosis I found the filter capacitor was Burnt instead of changing the capacitor with new one , I did direct jumper , this cause backlight came but the half side of lcd , how to get other half backlight of iPhone 6S
should I put the capacitor on , or change the backlight ic ?
Please share the solution I and Save the phone , as this is my first quation to the forum , please guide me, thank you .
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
There is no way to tell for sure without testing where the problem is. Backlight is brought to screen with one anode and two cathods. Each line protects the board with one filter, which is there to shield the backlight driver and components. Sometimes damage is limited to the filter, other times it goes further. Bridging a filter is a bad idea as any injury to the screen next time will likely directly destroy the backlight driver, capacitors, inductors and so on.
You can try replace all filters, if backlight is still half faulty you’ll have to dig deeper in the circuit.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
i change one capacitor , could you tell us which is another filter capacitor of backlight
из
@doctorgadget You'll have to replace FL4211, FL4212, FL4213 or make jumpers for testing purposes. They're not capacitors though, they're ferrite beads. If you were to bridge a capacitor all you would get would be a shorted to ground line.
из
I would recommend you to replace the entire screen.iPhone 6s Screen iPhone 6s Screen Replacement
Replace a screen compatible with iPhone 6s. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch, 750 x 1334 pixel IPS LCD Display, Front Camera Assembly, Earpiece Speaker, LCD Shield Plate, Cable Foam Pads, and Sensor Bracket. Изображение
Товар
iPhone 6s Screen
$54.99
Счет 0
Добавьте свой ответ
Ajit Sable буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 823
