Ноутбук ThinkPad X200 был выпущен в 2008 году. В нем используются новые технологии от модели X300, включая возможность установки твердотельного накопителя (SSD), опциональную встроенную камеру, широкоформатный дисплей 12,1 дюйма, опциональный модуль 3G WWAN, новый 9-ячеечный аккумулятор для увеличенного времени автономной работы до 9,8 часа, вес от 1,34 кг и процессор Intel Core 2 Duo с частотой до 2,66 ГГц.
Ethernet not detecting network
Hi,
Swapped my HDD for an SSD and installed a fresh copy of Win 10.
Naturally I had some driver issues, but try as I might, My LAN connection will state “Unidentified Network” and will not connect to the internet.
Wifi is working well and connects to the internet.
Tried the driver on: https://support.lenovo.com/il/en/downloa...
Adapter is detected as “Intel 82567LM Gigabit Network”
Laptop full model is: 7454-2HU
Thanks in advance
Это хороший вопрос?
Счет 0
9 Комментариев:
Hi @goom
Had you tried updating the laptop BIOS?
Had you tried using another LAN cable?
Had you tried connecting to another known working LAN port?
из Поделиться
Hi @goom ,
What is the status of the LAN adapter in Device Manager?
Go to Device Manager (right click Windows Start button, left side of Taskbar, find Device Manager link) > Network Adapters > right click LAN adapter entry > Properties > General Tab > Device Status.
Have you tried using the Troubleshooting program in Win 10?
Go to Control panel (click on Windows Start button left side of Taskbar) type Control Panel in search box > select Control Panel desktop app that appears in pop up window > Troubleshooting > Network and Internet > Connect to the internet and follow the prompts
из Поделиться
Will try BIOS.
Have tried different cables and routers.
LAN device is working and up to date.
Troubleshooter can't understand why I'm not getting an IP.
из Поделиться
Did you check the antenna wires to the wireless adapter? The connectors tend to be easy to take off but sometimes very hard to connect.
из Поделиться
Wirless adapter works flawlessly.
из Поделиться
Показать ещё 4 комментариев
Добавить комментарий
1 ответ
I suspect the wrong driver might be installed. I’d suggest finding the hardware ID of the wireless card and searching google with it to make sure you have the correct model of your wireless card.
To find the Hardware ID go to device manager—>device properties—> details tab—> and then choose “hardware id” from the drop down list. Copy one of the strings listed and paste it into google and see what comes up.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Goom буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 32
За все время: 1,856
