Выпущен 22 сентября 2017 года. Модели A1864, A1897. Доступны версии GSM или CDMA, с объемом памяти 64 или 256 ГБ; варианты цвета: золотистый, серебристый и «серый космос».
Overheating and drainage fast.
Hello,
i have a question.
I run an repair shop and i repaired like dozens of phones.
i recently refurbished my own iphone 8 plus device to make it look new.. but now my phone is overheating entirly but at the power button it is even warmer.
the phone also lose 1% every minute when using it.
-housing replaced
  • original battery
  • Oem screen
Это хороший вопрос?
Счет 3
1 Комментарий
I got the same problem :(
Have you fixed it?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Bad Tristar chip on the motherboard. Microsoldering required to repair it.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Checked chip.
Its fine.
I notice when i am using the phone with on spotify and when using sound true top speaker the phone is getting hot.
Any solutions for that?
из
So,
This is the place where it heats up.
https://ibb.co/8Y5zDpG
On the front and at the power button it heats. The most i feels like 40c back site is little warm.
Rest of the phone is not as warm as the top
из
Did you try a new battery? Also go into your settings go to battery and than battery health. If its below 82%, I recommend a new battery anyways.
Счет 0
2 Комментариев:
Changed housing,
Changed battery
Changed screen.
Everything works normal...
Just special apps like spotify , gaming its getting hotter as usual... and then the battery drains way faster.. like half of the time as before
I am running ios 12.2. i refurbished this one and i put my back up on this phone and had to update it. So i dont know if it was befoee the update aswell.. thats the problem.
Is it possible that it could be?
-faulty screen
-proximity sensor?
- copy power flex
- copy dock connector
из
Maybe just backup your phone and then do a DFU restore to see if that fixes it.
из
Добавьте свой ответ
glennjacobs буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 18
За всё время: 855
